AMD Multi-Monitor setup questions
2 Sep 2013
Hi all, hoping someone knows the answer to this one.
I've currently got an old ViewSonic VX2260WM in use whilst the recent Asus purchase has gone back in for replacement. The Asus will replace the ViewSonic when I get the replacement as the primary screen (unless it too has lots of pixel issues) with the ViewSonic later being VESA mounted for a second monitor display.
I know it's possible to have different resolution monitor setups without issues. But what I'm contemplating is getting something like a LG CINEMA 3D D2343P to play around with some 3D as well in the setup.
So the question is:
1. Can a HD7950 be used to power such a setup?
2. Can I get 1 display in 1080p, another in 1080p with 3D on the LG and 2560x1440 on the primary? Or is this simply not possible?
3. I know the older LG CINEMA display is compatible with AMD hardware, but I am unsure on the current one. Would I have any issues?
Thanks all.
