AMD OC'ing Advice
22 Oct 2010
Pontefract
I have just made my first AMD system, and i am lost in the OC'ing cell menu.
CPU: AMD phenom x2 560BE unlocked to AMD phenom x3 B60 BE (core 2 was dead so running core 0,1,3)
MB: MSI 870-C45
RAM: Corsair Value 4GB (2x2GB) DDR3 1333MHz
GFX: 8800GTS 640 OC2
Cooler: AC Freezer 7 pro V.2
the system in 4hr's stable with all setting to auto, CPU-Z shows core voltage @ 1.400
I am happy with the CPU as it unlocked giving my 50% more CPU, but if i can OC i would like to. All setting are set to auto.
Voltage options are (witch one do i adjust when pumping the FSB)
CPU Voltage
CPU VDD
CPU NB VDD Voltage
CPU NB Voltage
MY HT link: 2000 what would be the max as a ruff guide
CPU: 3.3, 16.5 multi, 200 FSB.
i would like to hit 4.0 witch i can do with the OC genie but it not stable aa the voltage's are all auto and HT link go throw the roof
And help would be super.
P.s i have an now unused water cooling system witch i will buy a new CPU block for if the CPU is a good OC'er???
