- 15 Feb 2011
- Slough
The only question I had regarding freesync is about what andybird said on one of the other threads, and this updated FAQ has done nothing to answer it.
Basically, if someone could find out from AMD if this is really the case or not i would be very interested to hear about it, since it sounds like a very odd way of doing thingsAMD's solution requires the GPU to guess how long the current frame is going to take to render, which it then sends with the last frame to tell the monitor how long to hold that frame for
Nvidia's solution lets the monitor hold the frame by itself and update when the new frame is actually ready
If AMD's "guess" is wrong then you either get unneccesary lag, or a stutter, they are also saying it takes up gpu time to generate the guess, so it will also impact frame rate, which is probably why they arent rolling it out to previous gens
