Tosk said:hi what heatsink and fan, would u go for to keep a AMD Opteron UP 146 clocked at 2.4
thx for any help
ive got a Arctic Cooling Freezer 64 Pro atm at stock and its not cooling it at all, as im hiting like 40c + in idle
Tosk said:ive redone it and its still hiting 40c to 45c at idle
ive also used some AS its seating just of 1 side not much tho
it could be my setup ie case and fans, i will just have to keep an eye on it atm and play about with it
Tosk said:IHS fitment what do you mean by that?
Tosk said:ah ic thanks
i think im gonna test the heatsink and fan on me m8s pc see what reading i get, i could use his heatsink as well to find out its its mine
thx guys
my case dont help i think its holding in the heat gonna have to put 2 more fans in to flow the air out
