Hello folks, I am looking to build a media centre biased PC and am trying to nail down the most suitable CPU.
I have learnt so far that you seem to get more for your money with AMD but I need the CPU to fit a certain criteria. Being a media centre biased build I need the thing to keep quite with no annoying whiring fan noises. I know fans and cases are getting pretty quiet now but the case will hopefully be quite slim so the less heat the thing produces in the first place the better.
That is why I'm thinking an all singing and dancing quad core AMD might be a bit power hungry compared to the similar priced dual core i3.
Can anyone pass any recommendations?
As mentioned in another thread I have just started, the machine might end up taking over the role of the current games console aswell so reasonable gaming ability might not be a bad thing. It's not critical though as I have not yet seen any form of nintendo wii or xbox connect equipment made available for the PC market which is the kind of thing the missus would want.
Cheers,
Smiler.
Cheers,
Smiler.
