AMD overclocking advice
29 May 2006
stoke-on-trent
AMD Athlon 64 3200+
ASUS A8R-MVP motherboard
I am trying to overclock this but i cant find the voltage i have found the pci voltage (which i presume is the voltage for the pci express slots) and i found another one but i forgot what it is called (it is next to the option where you can change the htt multiplier. So what i want to know is which of these is the voltage i need to change if neither is then where do i find the option.
Also how high could i get the temps and still be safe????? :D
htt multi 10x or 4x??????
can someone please help me out with ocing because i have read a few posts (including the syicky above and the sticky says keep the htt multi at 10x but another post i read says keep it at 4x so which do i keep it at????
if someone could give me a step-by-step guide it would be very much apreciated
:D
