AMD Overclocking Utility
15 Sep 2005
Anyone got any opinions on AOD ... especially its stability test.
I've been using it and have found that it reports errors in setups that run OK for hours in Prime. I've also recently got suspicions about its "boost mode" (that's when the green circle has a red edge ... from what I read it seems to change the power settings - n.b. on early Phenoms boost mode disables the TLB fix) as well.
Anyone else usde AOD stability test ... is something from the chip manufacturer more likely to be the correct stress test or is it jsut buggy and I should rely on OCCT/Prime etc instead
