- 27 Aug 2007
- Whitley Bay
Oh well, all change on the upgrade front
As I've posted before I currently have:
Gigabyte GA-K8NS Ultra 939 with AMD64 and 2GB(4x512) of DDR400
1x250GB IDE
1x40GB IDE (for windows I'm afraid)
2x80GB SATA
CD-Writer
DVD-Writer
AGP NVIDIA 6600GT Dual DVI connected to 2 Iiyama Prolite E431s @ 1280x1024
Elsa Synergy 2 PCI connect to another Iiyama Prolite E431S
600W PSU - Zalman
I intended buying a Q6600 and the Asrock DualSATA2 775 mobo. Keep my 6600GT and sell the DDR and buy 2GB of DDR2. And basically keep the rest as is.
Now... I may be able to pick up a Phenom 9500 for £30. So I'm thinking of picking up the Asrock AM2NF3-VSTA mobo, still get 2gb of DDR2 and go that route. This way I still get a good boost over what I have for half the price.
Questions are:
1. What do people think?
2. Is there a performance hit using the Phenom in a AM2 mobo as opposed to AM2+?
3. Is the 'bug' in the Phenoms fixable as I've heard? I plan on doing a fair bit of virtualisation stuff but have the heard the bug is only an issue in VERY heavy loads?
4. Any other suitable mobos for this setup?
5. Any suggestions on a cheap PCI-E card (nVidia) and mobo in case I need to get a new mobo instead? Need dual DVI.
Main pluses for me here are I get a reasonable quad system for minimal outlay. I know the Q6600 is a great chip. I just can't really push the budget too much at the moment. If I get the Phenom at that price I can then afford to put an extra 2GB in which will help the VM stuff.
Thoughts and comments much appreciated, guys.
Cheers
Andy
1x250GB IDE
2x80GB SATA
CD-Writer
DVD-Writer
600W PSU - Zalman
Questions are:
Cheers
Andy
