So i had this CPU not to long ago but only got a 3rd party cooler a week ago
All i want is around 3.6Ghz OC or even maybe 3.8Ghz Depends on Temps
Well anywayz i been having problems
When i try and OC it is not stable
im new to a quad core and Overclocking
Last CPU i had was a AMD x2 3800+
which is totaly different to what i have now obv :S
so im abit :S
I think most of the unstable is coming from my ram which are
RAM
My Mobo is
MoBo
And obv i have the AMD x2 965 3.4Ghz
Right if i leave everything how they are and not mess with BIOS
my CPU Volt is 1.45v
But my ram Runs at 1066Mhz :S and CPU-z says it
Max Bandwidth is 533Mhz?
but the Part number is OCZ3OB1600LV2G
and says Voltage at 1.5v
But on OC they say 1.65V but when ever i set them to 1600Mhz and 9,9,9,24 with 1.65v my system is unstable :S i tryed them at 1.6v but didn't work to.
Atm im running at 3.6Ghz 200x18 memory at 1600Mhz 9,9,924 but in BIOS i left Both there Voltages to AUTO and normally after a while my PC just crashes or normally after i restart my BIOS says can not run Overclock set.
im gettin
because i brought
CPU cooler
Just to keep my CPU cool so i could OC and it is just not working
I ran memtest when Ram was running at 1066Mhz and it didn't find any errors im going run it now which 1600Mhz. i quickly ran prime95 *for around 10 mins* and my CPU was going around 45c i just rly wanted to check because the last few times i tryed OC as soon as i ran prime95 my PC crashed or it crashes just after loadup of windows 7 when it says please wait and the windows logo shows it crashes half way though that.
So any got any ideas?
or anyone with this board or ram?
so im abit :S
RAM
My Mobo is
MoBo
im gettin
CPU cooler
