Hi guys I've bought some parts to build a 2nd rig to go in my bedroom and I have a few questions about it.
1) do you overclock the phenom the same way you do an fx8350? If not is there a decent guide for the phenom ii x6 please.
2) I've bought a gigabyte ga-970a-ds3 and it doesn't have a vrm heat sink only north and south bridge. I'm going to be running a h60 v2 on the CPU with a 120mm exhaust fan on it and intake fans a 120mm in the front, 120mm in the bottom and 2 140mm on the side panel blowing straight at the socket area. Will this be sufficient or should I also mount a 120mm literally above the vrm blowing onto it?
Many thanks in advance, Damien.
