Anyone else got this? Do you find the default fan noise to be quite loud? It's pretty annoying.
Is there a program I can download to see temps of the processor and manually set fan speed so I can check if it is indeed that fan making the racket?
If it is, will a watercooling solution eliminate that noise completely and offer the same level/more cooling?
