Hi there, Can someone recommend me a good overclock for this card?
The normal stats are:
GPU Clock(Mhz): 1070
Memory Block(Mhz) 6400
That would be great, thanks!
1200/1600 would be a good overclock. But you might need to increase voltage to get the core stable at that speed.
Not straight away. Just move it up in small increments on the core only first of all, check for stability, if no artifacting, increase, then repeat till you get some artifacting. Once you have found your stable core clock, repeat with the memory.
what score did you get?Wow that's a great overclockwhat score did you get?
