- 27 Oct 2013
Here's the system, - it's watercooled.
Operating System
Windows 8.1 Pro 64-bit
CPU
AMD FX-9590 14 °C
Vishera 32nm Technology
RAM
16.0GB Dual-Channel DDR3 @ 669MHz (9-9-9-24)
Motherboard
Gigabyte Technology Co., Ltd. 990FXA-UD7 (CPU 1) 34 °C
Graphics
W2252 (1680x1050@60Hz)
4096MB ATI AMD Radeon R9 200 Series (ATI) 33 °C
Storage
238GB Samsung SSD 840 PRO Series (SSD) 30 °C
931GB SAMSUNG HD103UJ (SATA) 24 °C
1863GB Seagate ST2000DM001-1CH164 (SATA) 30 °C
Optical Drives
HP DVD Writer 1260v
PIONEER BD-ROM BDC-202 ATA Device
Audio
Realtek High Definition Audio
All running fine......played quite a bit of BF4 and other FPS games. Started playing Call of Duty Advanced Warfare, and just recently within the last month, the PC as soon as I start COD AW reboots (not every time, but more often than not)......no blue screen and nothing in the Event Viewer except to say the PC didn't shut down cleanly.
I've also noticed on the times when I have managed to get into the game that there is a buzzing noise from the GFX card area. I thought maybe the PSU was not supplying the correct voltage so a changed the PSU to a Seasonic 80Plus Platinum 1000w ( a bit overkill, but I wanted to make sure there would be no stress.) On my specs above, the temperatures show everything whilst running at idle. The CPU & GFX card very rarely get above 40, so I don't believe it is a overheating problem. The noise only appears when there is a GFX intensive screen and only in this game. I am playing at 1680 x 1050 @ 60hz which is the recommended screen resolution.
I'm just about to get another <£100 GFX card to see if the noise appears from somewhere else and it's not the GFX card.....if it is, I hope it can still be RMA'd.
I have got the game and Steam installed on the Seagate 2tb drive and not the SSD C drive....has anyone heard that this could cause this problem?
Anyone else got any ideas to what could be causing the reboot problem?
Operating System
CPU
AMD FX-9590 14 °C
RAM
Motherboard
Graphics
Storage
Optical Drives
HP DVD Writer 1260v
Audio
