markpne19 said:both say ultra dma 2 the other says ultra dma 4 and yes i have installed a few games lately
Corasik said:Could be a sign that you have a game with Starforce copy protection, and its messing up the system.
Further to what Binaryknight suggests, check that the drives have not reverted to PIO mode instead of ATA. Even ATA1 is a DMA mode transfer, which uses very little cpu intervention, PIO mode on the other hand, every bit of data transfered from disk>ram>disk passes through the cpu.
To check, you can look in the control panel > system > hardware > device manager.
Once there look at the IDE/ATAPI controllers, under that will be 1 or more Primary, and Secondary controllers, inspect each one , under advanced settings it will show your current transfer mode.
If the setting is DMA if available, but the current transfer mode is PIO, then the easiest way to fix it would be uninstall the controller, and reboot. Windows will redetect it, and should restore UltraDMA mode.
You 'May' need to reinstall your chipset drivers after this is done, but normally it will already have all the files needed to get you going.
