AMD Ryzen 1700X Overclocking
20 May 2018
Hello, overclockers. :)
I'm new at world of the overclocking and i might need help.
I have a question how can i set up my CPU and RAM memory to work on 3.8 GHz stable and 3200 MHz on 1.35 voltage (RAM).
So, my PC specs:
MB: Asus Crosshair VI Hero
CPU: AMD Ryzen 1700X
RAM: Corsair Dominator Platinum DIMM Kit - ROG Edition 16GB 3200MHz
Cooling: Corsair Hydro Series H115i
PS: Corsair Professional Series HX750i 750W
Video: ASUS Radeon RX 580 TOP Edition 8GB
SSD: Samsung 250GB NVMe SSD 960 EVO
HDD: Seagate Firecuda 2TB
I would like to set the CPU to work on 3.8 GHz on low voltage 1.35V (if it's possible).
RAM memory right now is set to 3200 MHz on 1.35-1.32V ,not sure.
I have took some pictures on my current BIOS for my motherboard which is with the latest update "CROSSHAIR VI HERO BIOS 6004"
ram is working on XMP @ 3200mhz cl 16 18 18 36 54 @ 1.35v
you'll probably find you can run the 1700 @ 3.8 lower than 1.35v. I don't know how to overclock using your motherboard wither it is offset or just changing the multiplier. should be videos on youtube that show you what to do as well as forums such as here and overclock.net
Set 3.8 multiplier in bios, set manual voltage to 1.35v. See if it benches. If not will either need more voltage or perhaps LLC to stabilise it.
