AMD Ryzen 5 3600 Processor budget cpu cooler, None overclocked cpu
14 Jul 2009
Hi, I am using AMD Ryzen 5 3600 Processor with the default heatsink. Now, this is so much bugging me of wine it's making so I have decided to buy third part one. I need some help in this as I need a cooler that is easy to install and quite and that won't break the bank. What do you recommend?
Several 120mm tower coolers for around that money - CM Hyper 212 Black, Be Quiet Pure Rock 2, pretty much any "name brand" 120mm tower cooler in budget should do the job.
The Hyper 212 Black has been flawless on my 3600 but I think the Artic Freezer eSports duo mentioned above appears to be better value at the price point.
CR-1000 120MM RGB CPU COOLER - BLACK
Please try to find a review of that cooler or any cooler you are considering before you purchase it, it's also important to ensure the review is undertaken on a Ryzen 3000 (Zen2) CPU as many coolers are specifically designed for monolithic dies (Intel & earlier AMD) and do not perform well with chiplet architecture that your CPU uses. This is why I specifically recommended a cooler that has been tested with Zen2 and has very good performance.
