AMD Ryzen 5800X or 5900X
25 Aug 2008
York, UK
Hi,
I currently have a 3700X and have the urge to upgrade to either of the above (at the same time of upgrading my gfx card from my current 1080Ti to a RTX 3080).
My PC is mainly used for gaming, would I be better off future-proofing more with the 12 cores on the 5900X? Is it worth the extra £s?
Thanks
Personally for gaming i don't think the 5900X is worth it over the 5800X, having said that there are some occasions where the extra 4 cores make a difference so if you just want the best and you can afford it go for it...
5900X is a little slower in lightly threaded tasks but considerably faster in multithreaded. Both are stupidly fast desktop chips and much faster than a 3700X, especially for gaming with a RTX 3080. I seen 10-15% performance jumps recently at 4K between a 3700X and 5900X.
Personally I think the 5900X is worth the extra money.
I'd wait for the Zen3 update with 3D cache coming early next year, not long to wait and especially for gaming will be a nice bump over 'plain' Zen3...
Ok I will try, I didn't know that.....but my patience may get the better of me :)
I had a 3700X and upgraded to a 5900X and it was definetly worth it! However, if the vCache versions are coming out soon, I would have held on - 3700X is still plenty! For now, focus on getting a new GPU as the 1080ti is becoming old now :)
Yeah, Zen3 is still an upgrade but AMD have given a 'date' of Q1 2022 for the vCache versions, and given numbers of 10-25% IPC improvement and 15% average in games over Zen3...
Of course this is gaming at 1080p or lower, as always with CPU related numbers... If you're still rocking a 1080Ti you might be better off getting a new GPU?
I found the upgrade from a ryzen 5 3600 to ryzen 7 5800X with a 3080 at 1440p to be quite small in terms fps gains of around 0-10% so I'd definetly wait for the Vcache versions
You wouldn't benefit from a VCache version at all as it sounds like the games you play are GPU locked, Zen 2 to Zen 3 is a huge upgrade where the CPU matters, anything up to 50%.
I won't be upgrading to the Vcache versions myself from Zen 3 as its not worth it but what I'm saying to OP is don't expect to see huge FPS increase going from a 3700X to a 5800X or 5900X as in most games it won't be noticeable especially at 1440+ outside of the odd few exceptions or old games with don't really tax the GPU and already running at over 200+ fps.
Your games must only use 6 cores or the Nvidia RTX scheduler must be really bad. There is more than 10% between a 3600 and 3700X.
Most games do only use 6 cores or less which is why the 5600X isn't much different in gaming then any of the other higher core count Zen 3 CPUs.
No, most games scale well past that. Maybe most of the games you play only scale to 6 cores or the RTX3080 only scales to 6 cores.
Most games do not scale past 6 cores hense why it's widely accepted that if your just gaming then a 6 core CPU is fine.
