Amd Ryzen 7600 - Does it have its own gpu
5 May 2004
Hi all
Been out of the building game since 2009 lol. I have mainly stuck to laptops and xbox. My laptop needs replacing and i thought i may as well go for a matx build with as small a case as possible with future gaming (casual) in mind to avoid conflict with the wife over the tv.
I intend to keep my current monitor ( 24 inch 1080p 100hz ) The plan is start the build and finish it off in time with a small gpu ( possibly 4060 ) but at present this would be out of budget.
Im looking at getting the Ryzen 5 7600 but im not sure if it has its own basic gpu built in. I would only need it to be able to do basic browsing/emails/word etc and then must be able to handle youtube/netflix etc etc .
Thanks
All 7000/9000 CPUs except for F are good, yup.
The G models have a better one which you can do light gaming with, but the other CPUs are fine for basic desktop use.
Excellent thanks i am just looking at air coolers and seems a thermalright pierless assasin is prob a good option to cool it
I often suggest the freezer 36 just because it is a bit cheaper, but nothing wrong with the peerless assassin/phantom spirit.
Note the 7600 has cooler included, 7600X does not.
