AMD Ryzen Pwer plan?. 3700x
10 Feb 2011
Ive noticed on Ryzen power plan that it keeps changing from AMD Ryzen balanced to High performance. Only thing ive done in the bios is enabled XMP on a x570 aours Pro.
Any one else getting this?.
Ive noticed on Ryzen power plan that it keeps changing from AMD Ryzen balanced to High performance. Only thing ive done in the bios in enabled XMP on a x570 aours Pro.
Nope. I use 1usmus and even if wipe the bios drivers it still remains. Do you use the latest chipset version from AMD and not your motherboard manufacturer?
Very strange just did a clean install for sake of it using latest installer from windows on usb. Default bios setting and F11 bios which is one down from F12e which I don't use as its beta.
Clean install and updated windows and new drivers from AMD not the motherboard website driver and it still doing it. I cant remember how I found out the problem I think I was just checking to see what power plan I was using and noticed it was on high performance and changed back to AMD balance and even tried AMD high prtformance but it still changes back to normal high performance.
Ive never heard of 1Usmus be for but have heard of the ultimate power plan.
Edit very strange again. Well having the power plan open it was on balanced and when I turned on oculus app it auto switched to high performance. Is this normal?.
1usmus is great for light loads which is everything (incl gaming) except if you run all core benchmarks & all core rendering.
