AMD Software - Zero RPM Fan not available with custom curve
1 Apr 2019
Hi all,
Currently running a Sapphire Vega 56 Pulse.
Is there any way to retain Zero RPM fan functionality (fans off when idle) while also setting a custom fan curve?
With the AMD softare if you enable Advanced Control, the Zero RPM toggle disappears and the fans will always be on at idle. Its also not possible to set fan RPM to zero with the curve.
I'd rather not use a third party application, but if that's the only way to get zero RPM behaviour and a custom fan curve then I will consider it.
iirc ( have the same card ) you have to save the settings to file, edit the file, then re-import them. A bit of a faff.
