AMD Spec pc randomly stopped working?!
11 Jan 2011
Well basicly my problem has been that my pc randomly stopped working while I was gaming. The screen suddenly went black and the pc started making massive amounts of noise and I was holding down the front panel power button for 20 seconds and then nothing happend, so then I swiched the psu off at the back swich of my psu. Then when I started it back up it was making the same noise and nothing was appearing on the screen so then I had to do the same thing again with the back of the psu.
So far I have try'ed different power source, graphics card, harddrive. While trying a different power supply I noticed that the pc turned off when I pressed the front panel to turn it off. (only a 350W compared to the 700W I have) However there was nothing on the screen it was saying it was connected. So I dont know if it was because there wasnt enough power or what.
So what does everyone think? Would appreciate any suggestions very much.
XFX ATI Radeon HD 4890 1024MB GDDR5 PCI-Express Graphics Card
AMD Phenom II X4 Quad Core 955 Black Edition 3.2GHz (Socket AM3) - Retail
Gigabyte GA-MA770T-UD3P AMD 770 (Socket AM3) PCI-Express DDR3 Motherboard
OCZ ModXStream Pro 700w Silent SLI Ready ATX2 Modular Power Supply
OCZ Reaper 4GB (2x2GB) DDR3 PC3-10666C6 1333MHz Dual Channel (OCZ3RPR13334GKK)
Western Digital Caviar Green 750GB SATA-II 32MB Cache - OEM (WD7500AADS)
Antec 300 Three Hundred Ultimate Gaming Case - Black (No PSU)
Pioneer DVR-217FBK 22x DVD±RW SATA Dual Layer LabelFlash ReWriter (Black) - OEM
