- 5 Apr 2008
I ordered some stock coolers (http://www.overclockers.co.uk/showproduct.php?prodid=HS-000-OP) which just arrived. Sadly they're not the type pictured, they're the heatpipe version. Is it pot luck which type you get or are there only heatpipe coolers available?
I was really looking for the plain block of aluminium type as I had a different purpose in mind for them. Specifically I need to drill and tap some M3 holes on there for mounting power transistors
