Chaps,
For the last month or so i have been unable to start up the AMD Vision Engine Control Center (the new catalyst control center if you have an AMD board as well). I cannot start it up. When i right click on desktop and choose it i get the spinning circle for a few seconds then nothing..
I have tried multiple fixes scattered around the net via google including:
Uninstalling and re-installing the AMD drivers
Removing all instances of C++
Removing and re-installing Microsoft .net and associated service packs
Trawling for some public key listed to remove it (i dont have it)
And any number of other things that i just cant remember... Does anyone have any further suggestions? I would rather not re install Windows but at the moment i can't see a way around it.
I am running the following:
gigabyte GA-MA790XT-UD4P mobo
Asus HD4890
4 gig DDR3
Windows 7 64bit
Cheers
Marcus.
Asus HD4890
4 gig DDR3
Windows 7 64bit
Cheers
Marcus.
