is there anything that can be done about this
its not a game profile i want i just the fan off function turning off.
im not even overclocking i just dont like my gpu to sit at 55c all day when it can sit at 30c
I'm getting fed up of seeing a message telling my AMD wattman reset defaults due to unexpected amd failure.
ive had no system failure and it resets ever day or 2. is there anything that can be done about this
None at all.Are you using other programs at the same time? They can interfere with the driver controls, I think.
There should be an option to not install it, amd know it’s crapIt's Wattman, it's generally a buggy piece of ****. Had my own issues with it since it 'launched'.
That’s what a 5 year warranty is for, and heat is the number killer if hardware. If you gpu sits at 50c for 12hr a day it’s not good compared to 30cWhy though. If anything its extending your GPU's life doing this because the fans aren't running all the time. Fans fail much more often than anything else on a GPU.
Sadly not.Does your card have a different bios where there is no fan stop?
I'm also getting that message all the time too.
Tbf I haven’t no. I will save my bios and reset then test for a few days.Have you tried turning off fastboot?
If that doesn't work try disabling any over/underclock and run at stock settings to test.
If that try removing (not just disabling) and other overclocking software such as Afterburner.
Welcome to AMD GPU drivers.
Only fix in my experience is going with an Nvidia GPU.
I mean you could move to another Radeon but the likely hood of this replicating is big.
Everyone will comment all kinds of crazy changes to your system avoiding the real issue, the AMD drivers being craptastic.
You might be able to use more power tools to change the fan profile permanently. Someone else probably knows here.the drivers are fine, all games work fine, FPS are fine. No crash’s or anything.
out of interest how easy is it to disable fan off on your gpu. On a 1060 6g I had years ago your couldn’t. The gpu wiild hit 55c and the fan would kick in at 60% scream like your mum and then go off… that was a much better solution
I had to bios mod the card
i have had a google to see if it can be bios modded, because i did mod my 5600xt(same problem different vender) but i just cant find anything and i dont want to just poke about and hope for the bestYou might be able to use more power tools to change the fan profile permanently. Someone else probably knows here.
lol, dose sound about right TBFSame, all fine here. When people have problems it's usually PEBCAK![]()
"I'm getting fed up of seeing a message telling my AMD wattman reset defaults due to unexpected amd failure.
AMD Wattman is not the driver. its a bolt on and it poo but the driver works fine
the "hope for the best" was about not wanting to mod a bios not knoing what "I" was doing or is that also the fault of AMD
interacts directly with the driver
