Hi,
I have just bought some upgrade components including an AMD Wraith Max cooler. I have a couple of questions that I hope you can help with
Cheers,
Nigel
- The fan comes with three leads, one is permanently attached which is for the fan. The other two are detachable and plug into sockets on the fan. I assume that these are for the LED lighting, but why are there two. At the board end one has a 4x1 plug and the other has a USB 2.0 header plug. But they also have different sockets at the fan end. Are these both for the LED lighting, if so I assume you only ever fit one of them, if so why would you pick one over the other. And if you aren’t interested in the LED lighting I assume you don’t need to fit either.
 - Thermal paste. Is the pre-installed stuff any good? Or should I use third party stuff? I have some Thermal Grizzly Kryonaut.
Cheers,
Nigel
