dont think so my x2 6000 is running at 29 idle and 45 loadMADEinSTOKE said:hi there
i used to run dual opterons 2220 se and they sat at 60 degrees they were the 125 watts the same as the athlon 6000 you,re running ihad akasa 859 heatsinks on them but they used to keep overclocked x2's at 30 degrees idle ....i just think 125 watt models need water to cool them
Massive Attack said:dont think so my x2 6000 is running at 29 idle and 45 loadim using a zalman cnps 9700 , OP have u got cool and quite on in the bios if not put it on right away also while in windows right click desktop>properties>screensaver>power> then select MINIMAL POWER MANAGEMENT from the drop down list this will run you cpu at 1ghz idle and when load gradually increase it will change the multiplyer from 5 upto 15 which is 3ghz
really, i am using the zalman paste that came with the cooler i find it a lot better than as5 have u got cool and quite on?Greenlizard0 said:I have exactly that setup but I'm running it 46 idle..hmm...I may have to look into this :/
