AMD64 3000+ overclock.
26 Oct 2006
London
Hey guys, first post so hello :D
Just want to ask a few question about my current options, recently I have been fiddling with my AMD64 3000+, its in a MSI K8N Neo2, with some geil dual channel (currently at 2.5).
Basically I've started to his a few blockades. And have two current options.
Either:
Option A:
FSB: 245
HT: 4x
Clock: 2.2ghz
Ram: 200mhz (mem div: 166mhz)
Or...
Option B:
FSB: 285
HT: 3x
Clock: 2.5
Ram: 183mhz (mem div: 133mhz)
I was just wondering which option gets the most out of my system. With option B I'm getting a quicker SuperPI times, and I seem to be gettin about 10 fps extra in games such as CS:S than I did with option A, but am I losing out on everyday desktop performace and encoding etc, because of the decreased read and write bandwidth, or is it better to have the cpu clocking faster?
I'm hoping to get a few more mhz outta my fsb with these lower ratios though, but I'm only on stock voltages atm, with a stock cooler, and at the 290 mark my system locks when doing prime95, so I assume increased voltage is in order, which will require some form of after market cooling to deal with the increased heat. Also does anyone no the limitations of my motherboard?
Sorry for the bombardment of questions, all replys greatly appreciated :D
Yer, I'm restricted though, as the ram is pritty budget, and I don't have the money round for some new stuff.
Would losening the timings help in anyways?
Option B, with A64 clock speed is king.
For the last time there is no 1:1 on A64 as ALL ram speeds run on a divider from the CPU speed ;)
He speaks the truth! surley your ram will do at least 215 @ cas2.5 with 2.8v
hmm my ram is on a divider and im getting 2.8GHz out my 64 3000, 311FSB x 9MULTI, mem div is 133Mhz so its actually at 209Mhz if i remember, thats with OCZ value ram.
