nbkpsycho said:are you using a devider ? have u tried more voltage? whats your HTT ?
nbkpsycho said:Set a ram devider (i use 166) and set your HTT at 4x and then increase the HTT. Keep an eye on the cpu temps as you go
GhostyUK said:Is this the correct stock speed for this cpu because i have seen some setups on overclockers.com and they are running a 2700ghz with stock fan.... I can only up mine to about 1900ghz![]()
locutus12 said:Ghz ??? i think youve set a new clocking record...
stock speed for a venice 3000 is 1800Mhz, i clocked mine to 2.5Ghz on my board. to over clock to those kinds of speeds, you either need to have highly clockable ram, or lower your ram speeds from 200 to 166 or 133, drop the HTT to 600 from 1000 (otherwise known as 3x) increase the voltage to 1.425 and continue to push up the front side bus speed.
m3csl2004 said:thats the 1 mate
change it to 133 for now![]()
cokecan72 said:is there an expert option somewhere int eh bios??? this option if there, will usually enable every setting to be changed by the user, as some of the settings needed may be blanked out if not??
