AMD'ers ... What is the Max CPU Temp I should run at ??
7 Mar 2013
North East
Ok messing with my OC and just wondering what temp are you AMD'ers living with ??
I obviously understand the lower the better but at what point do you say " Ok I'm happy with that"
I am at 59 @ 4.6 Ghz .....
Just noticed I had the core voltage set at 1.48 not sure why so this will be making it run a bit hotter as well... I'm still testing but thanks for the replys.
I have an [email protected] which runs no hotter than 45c under normal loads (i.e. not 2 hours of prime) and an [email protected] which is slighty cooler. Both run on H100i's. Temps from HW Monitor, so only as good as that.
ETA, throttling disabled on both, so full speed all the time.
I wouldn't be happy with 60, just because I'm happy with the above temps, nothing more scientific than that I am afraid!
Do amd really run this cool now? :O I just finished building my GF's pc and I've put an 8350 on a 970m pro3, one of the few mATX boards that suppport this chip and I was expecting fairly high temps. At stock after about 45 minutes of prime I hit 45 degrees, I was really shocked by how low it was. My 2700k at 4.8 hits that and its under water.
Thanks guys for the reply's.
I am running at 4.4 idle temps are 27 and load temp 48 so will stick with that for now as I am going to remove my cooler and re seat it ..... its been on there for almost 3 years so I'm sure it could do with it :)
