american truck simulator
28 Nov 2004
using this on the oculus using a oveclocked i7 3770k at 4.6ghz 16gb memory and gtx 980 ti sli. anyone got any good settings to use that should work good.
I have an identical system to you. ATS doesn't run as well as ETS 2. I normally play the game at 4k with SLI @ solid fps on max settings but because there is very little support for it in vr I have to resort to a single GPU mode to stop it causing hiccups in game. I need to run it again to check my settings but I'm sure I can get away with on high with some additional scaling to improve clarity at distance.
