AMP! EXTREAM
11 Nov 2012
hi guy's posted other day about cards I'm going to go with 2 amp extreme's
there big card's I'm using rampage 1v formula and a phobus sond card
do you think they will fit? :D
will fit but ud have to have the amps in pci 1 & 3 and the soundcard in the top pcie x1.
The zotac amp is a 3 slot card
Might fit, but the temps will make the top card throttle and you'll lose some performance. It will also be louder and warmer (Cpu included).
I suggest getting a MSI gaming and the G10+h55 and using it as top card or the reference and getting the EVGA AIO cooler.
Triple slot in SLI is a mistake you don't want to make.
Personally one of them beasts will last you at least a year @ 4K, then buy another one cheaper. You'll also get a better idea as if you'll get 2 comfortably in your case as they're wide.
Huge cards like that are not really ideal in SLI imo. I do like the idea of one dual slot AIO cooled card with a quiet non reference card.
i have a Corsair Hydro Series H100 for cpu
how bout the Inno3D GeForce GTX 980Ti X3 Ultra 6144MB
might leave space for sound? card also have
COSMOS II case so maybe that will help with cooling
The inno3d Hybrid on offer, that's the best option you have.
Trust what people are saying, two non reference in SLI is bad (personal experience). It's not about space, is about having too much hot air in the case.
