- 4 Nov 2004
- Norn' Iron'
Been looking on a well known auction site for an amp to power 2 10" subs, need something that will do 4ohm with a fair whack of power. I will be taking a feed from my Yamaha AV-Receiver, using the sub output and splitting it using a Y splitter to connect into the below amp in question.
Now onto the question:
The sub output from the Yam is 20-120hz. The amp that will be powering the subs is 20hz-25khz, is it okay to go ahead without using a crossover and connect the subs straight to the amp as it will only be receiving 20-120hz
PA Amplifier "IMPACT-1000"
Art Nr: AW1583048
1600 watts power!
High-performance-amplifier with a 19'' rack/case
High power, authentic sound and a persuasive design!
The 19'' dimension allows it to be installed as easy as winking.
• power 2x 800 watts max. at 4 Ohm
• power 2x 356 watts RMS 4 Ohm
• split controller for volume left/right
• two level meter for the left and right canal with 8 blue and super-bright LEDs
• front-sided on/off-button + power-LED
• input over cinch/RCA or 6,3mm jack
• speaker- connection optionally through XLR, screw-terminal or Speacon/PA-plug
• frequency range 20Hz-25kHz
• signal-to-noise ratio 80dB(decibel)
• distortion factor <0,3%
• safety switch (short-circuit-resistant)
Art Nr: AW1583048
1600 watts power!
