We recently dropped TV from our Virgin package to save money and are just using the ariel plugged into the TV for freeview at the moment. The problem is that as soon as the Amp is switched on the signal cuts out almost completely, if it's off then it's perfectly fine.
I'm thinking it could be the cable as it's just an ancient one that was in the loft, and it's about 5m long when it only needs to be 1m. Can anyone suggest a cable that might not be interfered with by the amp? I assume shielded of some sort.
If that doesn't work then i guess it'll be a new cabinet so the amp can be placed at the other side.
lol
