- 30 Oct 2002
- Inverness (UK)
Hello folks,
After making my Cisco switch quiet, I now want to add a couple of 4" CC's to it.
But, the only available power source is 240VAC.
I have had a look on an electronics store, and the only one that will fit is a 1A power supply.
Does anyone know how many amps a pair of 4" CC's and/or 12" CC would use?
I have hunted on google but there seems to be a lot of different uses for CC's.
Thanks.
(I've never managed to get my multi-meter to measure current... Think I need to RTFM
EDIT - Some adding of words into Google seemed to find one make of CC's taking 500mA (+- 30mA).
I take it all will be around the same value - Therefore 1A being plenty??
Thanks.
)EDIT - Some adding of words into Google seemed to find one make of CC's taking 500mA (+- 30mA).
