So I have been in the process of undoing my maximum OC on my GPU to allow my system to run a lot quieter but also run with less juice used.
I used Horizon Zero Dawn to test power consumption and noise whilst adjusting clocks / voltage / power limit and fan control.
From 2055mhz down to 1850mhz, I only lost about 5 FPS..., with these settings below.
The clock speeds range between 1850-2010mhz dependant on the game and power load.
So if it is only 5 FPS, why are they trying to clock these cards so high from factory?
Also I would like to note.. capping my FPS to the lowest number hit, so for example, Metro Exodus Enhanced with RT on and PhysX will average somewhere around 89 FPS with lows in the 70's, So I capped it to 70 FPS for a solid experience..
109 watts used and the GPU sat at like 1290mhz max, 47c top temperature.
I know it is a very different generation but like 700mhz base clock vs 850mhz on the GTX 480 would net an average boost of around 11 FPS.
