- 30 Sep 2013
- Bristol, UK
Against my own will, I have succumb to buying a new ATX case instead of using my already bought Micro ATX case as the motherboards available for them are quite shoddy (AM3+ socket wise). Anyway, I have decided to get a normal sized ATX case but here are my needs:
- It need to be able to support bigger cards such as the GTX 780.
That is basically it as I am looking towards the future with this build as currently I will only be running a 270X at max until I have enough money. Anyway, It needs to be quite cheap as I'm already far off from my budget but still good enough to support the newer features such as USB 3.0. So I'm probably thinking that it will cost more as a result... anyway, any help would be greatly appreciated
except for cable management
