An Audio player that allows bookmarks help!
Caporegime
24 Dec 2005
Autonomy
Hi there,
My students need to playback audio files and within the files make bookmarks.
Audacity has like a flag option,
But I would like something free and simple to use.
I have had a look at BS player http://www.bsplayer.org/
and it does the bookmark of the audio file but I'm not sure were they are saved.
If you have any other ideas on this it would be appreciated.
foobar2000 will do it, using the bookmarks extension with the ColumnsUI interface.
It might fall down a bit on your "simple to use" requirement though - fb2k is an awesomely capable audio playback/management app, but even its biggest fans would admit there's a bit of a learning curve. Well worth it in the end though, if you have a use for all its functionality. :)
I've added that extension to my existing foobar v0.9.6.8 install and it works fine, thanks for the tip guys. :)
