Assuming it is a USB keyboard then then it will plug into any available USB port on the motherboard. Assuming the USB ports on the case are attached to the USB headers on the motherboard then you can plug them into the USB ports on the PC.
Should it be a PS/2 keyboard it will connect to the PS/2 port on the motherboard.
