- 17 Aug 2003
- Woburn Sand Dunes
I came across this just now, thought you guys might like to pick it apart and get stuck in. make yourself a tea or coffee while you're at it, its quite in depth. take a read:
http://sound.westhost.com/cables.htm
here's a link to a blind ABX on a few different speaker cables: http://www.provide.net/~djcarlst/abx_wire.htm
When it comes to cable constructions, everything makes a difference. Most (but not all) of these differences are measurable. What is at issue is whether these differences are audible ... or not, when tested properly using a blind A-B test. Sighted tests are at best unreliable, and at worst cause people to believe things that are simply untrue. The vast majority of all cable claims have no basis in reality, and rely on the placebo effect.
It is interesting that in a relatively non-demanding application such as an interconnect, a material such as aluminium would likely be sneered at by any audiophile, yet this very same material is used regularly in loudspeaker voice coils. I am reasonably sure that sonic performance of an aluminium interconnect would be deemed to fall way short of excellence, yet I hear (or read) no highly critical comments about using it in a voice coil. This is an extremely demanding role, and the performance of aluminium is (or can be) audibly and measurably worse than copper. *
re speaker cables:
Summary
Essentially, the main offenders in speaker leads are resistance and inductance. Of these, inductance is the hardest to minimise, and although usually small, it may still cause problems with some loads (see update, below). Many construction methods have been used, from multiple CAT-5 data cables, with the wires interconnected (usually all the coloured leads are deemed the +ve conductor, and all the white wires - the "mates" - are used as the negative). Because of the tight twist, the inductance is minimised, but at the expense of capacitance. In some cases, the capacitance may be high enough to cause instability in the amplifier, which not only does awful things to the sound, but can damage the amp.
