An issue with a fresh build, the System won't boot without GPU but CPU has onboard graphics. CPU issue and not motherboard?
29 Jul 2013
Sheffield
So I've tried 2 motherboards, 2 psus etc
only thing I don't have is another cpu
CPU: intel 10105 (not F says this on the cpu itself and in bios info)
Motherboard: Gigabyte H510M H Micro & Gigabyte H410M H V2
When I plug HDMI into the motherboard without CPU on CMOS reset etc fresh bios it boots up CPU up for 2 seconds then keeps rebooting, it will never post a display or get anywhere near a bios logo screen just fans come on for 2 seconds then go off
if I put a GPU in and put HDMI in there it boots and works fine, ran 100% CPU stress tests on the CPU for 30 mins no issues and seems stable and snappy with the m.2.
but I bought this not to use with a GPU for a server low power and low noise build and I'm confused as to why the onboard CPU GPU isn't working.
I've also tried forcing the motherboard to use it on both and it just does the same issue
I've tried reseating CPU, and repasting, but all pointless anyway as it works fine with GPU so I'm unsure what the issue is here? faulty CPU or something else?
