an old overclock finally died, almost 10 years @ 50% overclock
13 Mar 2004
years ago i put together a (then new) AMD Athlon XP xp2500 on an ABIT NF7 and promptly wound it up to 2.4ghz
it has run like that for years. temps were safe, it was a good overclock, prime stable etc.
it had been running a bit buggy and i thoguht it needed a window rebuild.
the other night it crashed all together. on boot it runs POST but stops at DMI pool data
both HDDs are still accessible (on another machine) so im guessing it was running bad and corrupted HDD1's windows install.
i think it shows that with a bit of OCing you can make a machine that will last 10 years, even if its only capable of web brousing now due to sheer lack of fire power.
surely it makes it cost effective? :D
I've still got an XP M Barton chip running at 2700 MHz on an NF7-S Rev 2 that's yet to die :D
Some odd USB issues on one port admittedly, but other than that it's still soldiering on!
How is this a 50% overclock?
If stock is 2ghz, then 50% would be 1ghz?
So you would be running at 3ghz, or am I missing something?
The stock speed is 1883Mhz but pretty much all of them would run at 2Ghz straight off with most getting up to 2.3-2.4Ghz no problem.
My 1700+ (1466MHz) 11 x 133 Thoroughbred ran a 50% OC for over five years at 2.2GHz with a 200MHz fsb, it was a bit noisy though with a 70mm delta fan on a thermalright SLK-800A copper heatsink running up to 5000rpm. Abit motherboard.
I had two of them, bought from OCUK for about £40 each new but one did blow through excessive heat and volts. Great CPU's for the day.
OK if stock is 1883mhz.
50% of 1883 is 941.
So a 50% OC would be 1883mhz+941mhz=2824mhz. Yeah?
BTW I've no idea about overclocks, but the math didn't look right.
hi there
firstly, its back alive, but being replaced.
i want to over clock another AMD, not sure if i wanna go Athlon or Phenom, any advice?
i may chuck a hybrid hdd in there too and the usual 4gb.
secondly, whoa there with the maths! i got the barton a long time ago. i thought the default clock speed was 1.6ghz. i ran it at 2ghz straight out the box, it never went slower than 200*11, i then settled at 2.4ghz. on 512mb it did run stable at 232*11 but never higher.
anyway, its alive again. sorted out the cooling (a ton of dust in there), took bios back to totally stock speed and voltage, formatted the HDD and reinstalled XP.
it ran prime over night so i might ramp it back upto 200*11.
