"An unsupported memory moduel was detected" Dell laptop problems
4 Feb 2004
Écosse
Purchased a stick of SDRAM for my Dell C400 Laptop from a seller on that well known auction site.
The spec is:-
512MB SDR SODIMM PC133 512 MB M 133Mhz 144PIN
144 PIN Memory
133 Mhz (backward compatible with PC 100/66)
SODIMM (DUAL IN-LINE MEMORY)
Non-ECC
Non-Parity
Unbuffered
64 X 8 Configuration
Gold leads
But when I fit it in my Dell C400 Laptop, I get the message:-
"An unsupported memory module was detected".
"A bad or unsupported memory module was detected. Please remove the unsupported memory module in Socket 1.????
Strike the F1 key to continue."
I'm pretty sure its the correct type of memory for the laptop and on the Crucial site it tells me that up to 1Gb is supported by my model.
So silly question, is it a faulty module or is there something in particular with the type of memory these Dell laptops require?.
No m8, it shuts down.
In fact I think I got it wrong when I said it says "Press F1 to continue".
It actually says "Press F1 to switch off/shutdown" or something similar. :(
Laptops are sometimes resentful of mixed RAM inside them. Quite a few will not work with another stick from another manufacturer, see if you can find a match to the one you already have.
Sadly, I think you are correct.
I just removed the keyboard and heatshield to remove the already fitted to the motherboard memory module.
When I finally got it to bits, its an Infineon 256Mb PC133 CL3 32x64 SODIMM thats under there.
I fitted the 512Mb SODIMM that I have and the attempted to switch the laptop on. The green power LED lit for a few seconds and then went off immediately. Not a thing showed on the screen. Nothing.
Removed it and put the original module back in and it powered up without any problem.
So I have either a duff chip or its just not compatible with the laptop at all, with or without the original memory module fitted.
Kinda strange, I was half expecting it to fire up with the new one fitted to the motherboard and the original removed, as its the same spec, albeit different manufacturers.
might be that the moduals are "locked" - the lappy wont use any memory without a specific string in the spd.
wouldnt be a shock to me anyway.
maybe an investigate with an spd tool could help (at your own risk)
Its a few years old now, one of those little C400 Ultra portable Dell's.
The chipset is the Intel 830M.
From the spec sheet, as far as memory goes, it says:-
Memory
Architecture
PCI33 SDRAM
Memory module socket
two (2) SODIMM sockets; one user-accessible
Memory module capacities
128, 256, and 512 MB
Memory type
3.3-V SODIMM
Standard memory
128 MB
Maximum memory
1024 MB
Memory clock speed
133 MHz
Well, I remember very little about that chipset but, (again a guess here) it would appear that the system will not support a 64x8 configuration which is what your new SODIMM is.
From above:
Most likely it would need to use a 512mb module made with 32 x 16mb ICs as opposed to 64 x 8.
