Analog/Digital Tuner
4 May 2004
I've been looking at the Hauppauge HVR 1300, which works with Linux (apparently). But according to the gentoo wiki, the hardware decoder is not supported.
What's the decoder for? I thought you only need an MPEG encoder?
Anyone have any other TV tuner (analog or analog + digital) that works with Linux?
TIA
The decoder is for out putting a decoded MP2 stream to your TV. Alternatively you can use your gfx card, but unless your card has HW decoding, then it'll use the CPU. Not really a problem as any CPU greater than a PIII 500 will decode a mp2 stream. Problem is if you are doing other things as well.
The best for linux last I checked are :
pvr 150
pvr 500 (basically 2x 150 glued together)
pvr 350
But not the 250 I think.
