Couple of problems with my new MacBook.
First up, Airport.
I've been using my MacBook fine wirelessly since I bought it, it picked up the connection fine and I was away. Now today it's decided that it's not going to work. Airport is turned on but it just won't find my wireless network. I've logged onto the router and no settings are any different, other laptops can see the network fine too.
Second problem, Transmission not downloading/connecting to torrents.
I've got UPnP turned on, on my router. I've opened up the network settings and it's set to "automatically map port". On my router it shows the port as 1412, same as port forwarding too. I type this into the network settings on Transmission and after aaaages of waiting I get a "cannot check port status". I've tried lots of different ports (which I know will work fine), tried turning the mapping off etc, nothing makes a bit of difference.
Any ideas? The wireless issue is pretty major and it's putting a downer on the whole Mac goodness thing.
First up, Airport.
