- 22 Jan 2014
Device: Nexus 4
Android Lollipop 5.0 downloaded from Google's update prompt
The new lock screen allows you to swipe down once to access the quick settings, such as Wifi, Mobile data, Aeroplane mode etc. without entering any form of password (my device is encrypted and has a pin code).
This allows anyone with physical access to turn off mobile data and WiFi connections, meaning AVG's software (Google's own Android Device Manager cannot either, despite saying 'successfully sent') cannot access your device remotely.
This makes it impossible for you to access the security features if your device goes walkies, such as location, lock, shout etc. (I've not tried the remote wipe, but I assume given it cannot access the other features, this will not work either).
I also have an app installed that means you cannot turn off the device from the lock screen (the traditional method of holding the power button) to prevent a potential thief from doing essentially what this flaw allows them to do i.e. shut off all ability to remotely connect to the device to prevent the owner from bricking it.
I'd be interested to know if anyone else has found this is the case with their device?
