Android Auto Waze
26 Oct 2013
Leicester
Hi all
I am using android auto APP on my phone, not plugged into a car
How can I launch Waze instead of google maps for navigation?
Thanks
If it's the same as the plug in version, long press the nav button to switch which app handles nav. You might need to be a part of the Waze beta for this to work correctly in the app version of android auto btw.
