Android development environment on OSX
GeX
GeX
17 Dec 2002
Manchester
Hi all.
I'm looking to sort out my Android development environment on my MacBook Pro. I have developed Android apps in the past but have done so on my (now retired) Windows 7 machine using the usual Eclipse + ADT toolset. I found Eclipse functional, if not a little clunky at times.
I've begun looking into other IDEs, and saw IntelliJ IDEA linked from the Android developer pages.
Has anyone used it? Is it any better / worse / any reason to use it over Eclipse? I guess an advantage that Eclipse has is that that is what we'll be using shortly at work for Android dev - but if IntelliJ IDEA has improvements that are worth using, then I really don't mind using two differing development environments.
Failing that, any other suggestions?
I haven't done any android dev as of yet but I do use intellij as my main ide. It just blows eclipse out of the water. The interface is just so much nicer and does the job really well.
Like you I found eclipse really clunky and finding things took ages.
If you can fork out the £100 or so for intellij. Its just so worth it
The main two IDEs i've used are Intellij (free version) and Eclipse.
I havn't used Intellij for adroid development, just Java EE, but I agree with agent paul. Much prefer it to Eclipse and will use it given the choice.
I believe you can use the free IntelliJ version for Android dev
You can indeed.
Thanks for the replies guys.
In the end, I setup Eclipse just to get an old project built - but I'll install IntelliJ tonight as well and get a feel for it. All the feedback I've seen suggests the same as you've said here. It's just 'better'.
