Android phone not auto-connecting to home wireless
9 Jun 2008
I'm have a problem with my phone running Android 4.1 (galaxy s3 mini). It doesn't autoconnect to the wireless at home, it just shows as saved/secured in the menu. There is no problem about connecting to it at all, I just have to tell it to connect everytime, and it doesn't ask for the password etc.
I have played with my router settings, selected a static wireless channel etc and noticed my phone will only autoconnect when I select wireless mixed G/N on my router even though my phone will connect and work on wireless N only mode.
Does anyone know why this would be?
Hi thanks all for your help so far, I have a Buffalo WHR-GP-GN running the DD-WRT software (just upgraded to latest build to see if that did anything).
I have testing my Dad's phone which is an S3 running Android 4.1.2, my S3 Mini is running 4.1.1. His auto-connects just fine, mine doesn't.
It's abit annoying really, if I use wireless NG mode it's ok, but this will make my wireless run slower?
