Hi, i'm new to android, and i'm new to the layouts. I have programmed java for a year, but this is driving me nuts.
I'd really really really appreciate if someone could look at this code, and tell me what's wrong with it ( I think, probably a lot ). All I want is for one thing to work, i'm not too fussed ( although will greatly accept ) about lots of other problems.
I made this in eclipse, copy/pasting it there will show you the issue.
I gave one of the rows the ID "Textyline". I would like this to be the height of the text within it. How come, when I set it to "wrap_content", it makes every row have a larger than necessary height, and pushes off the screen everything after the first 4 rows? All I would like is to avoid having a large black space under the text "Trial Held", by having the linearLayout height fit the text.
I'd really appreciate some help with this, I understand what a pain it is to look at anyone elses code ( especially mine as i'm new to this ).
Thanks so much!
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android
rientation="vertical" android:layout_width="fill_parent"
android:layout_height="fill_parent">
<LinearLayout android
rientation="horizontal"
android:layout_width="fill_parent" android:layout_height="fill_parent"
android:layout_weight="1">
<TextView android:mavity="center_horizontal"
android:background="#aa0000" android:layout_width="fill_parent"
android:layout_height="fill_parent" android:layout_weight="1" android:text="Credits: \n 2000"/>
<TextView android:text="green" android:mavity="center_horizontal"
android:background="#00aa00" android:layout_width="fill_parent"
android:layout_height="fill_parent" android:layout_weight="1" />
<TextView android:text="blue" android:mavity="center_horizontal"
android:background="#0000aa" android:layout_height="fill_parent" android:layout_weight="1" android:layout_width="fill_parent"/>
<TextView android:text="yellow" android:mavity="center_horizontal"
android:background="#aaaa00" android:layout_height="fill_parent" android:layout_weight="1" android:layout_width="fill_parent"/>
android:background="#aa00aa" android:layout_width="fill_parent"
</LinearLayout>
<TextView android:layout_width="fill_parent" android:layout_height="fill_parent" android:mavity="center_horizontal" android:layout_weight="1" android:layout_gravity="center_horizontal" android:text="A1" android:textSize="15pt"/><TextView android:textSize="15pt"
android:layout_weight="1" android:text="B1"/>
android:layout_weight="1" android:text="C1"/>
android:layout_weight="1" android:text="D1"/>
android:layout_weight="1" android:text="E1"/>
</LinearLayout>
android:layout_weight="1" android:text="A2"/>
android:layout_weight="1" android:text="B2"/>
<TextView android:text="C2" android:textSize="15pt"
<TextView android:text="D2" android:textSize="15pt"
<TextView android:text="E2" android:textSize="15pt"
</LinearLayout>
android:layout_weight="1" android:text="A3"/>
android:layout_weight="1" android:text="B3"/>
<TextView android:text="C3" android:textSize="15pt"
<TextView android:text="D3" android:textSize="15pt"
<TextView android:text="E3" android:textSize="15pt"
</LinearLayout>
android:layout_width="fill_parent" android:layout_weight="1" android:layout_height="fill_parent"/>
</LinearLayout>
<Button android:id="@+id/Button03" android:text="Hold" android:layout_height="fill_parent" android:layout_width="fill_parent" android:layout_weight="1"></Button><Button android:id="@+id/Button04" android:text="Hold" android:layout_height="fill_parent" android:layout_width="fill_parent" android:layout_weight="1"></Button><Button android:id="@+id/Button05" android:text="Hold" android:layout_height="fill_parent" android:layout_width="fill_parent" android:layout_weight="1"></Button><TextView android:text="E3" android:textSize="15pt"
</LinearLayout>
<TextView android:id="@+id/TextView01" android:text="1" android:layout_width="fill_parent" android:layout_weight="1" android:layout_height="fill_parent" android:layout_gravity="center_horizontal" android:mavity="center"></TextView>
<TextView android:id="@+id/TextView08" android:layout_weight="1" android:text="2" android:layout_width="fill_parent" android:layout_height="fill_parent" android:layout_gravity="center_horizontal" android:mavity="center"></TextView><TextView android:id="@+id/TextView07" android:layout_weight="1" android:text="3" android:layout_width="fill_parent" android:layout_height="fill_parent" android:layout_gravity="center_horizontal" android:mavity="center"></TextView><TextView android:id="@+id/TextView06" android:layout_weight="1" android:text="4" android:layout_width="fill_parent" android:layout_height="fill_parent" android:layout_gravity="center_horizontal" android:mavity="center"></TextView><TextView android:id="@+id/TextView05" android:layout_weight="1" android:text="5" android:layout_width="fill_parent" android:layout_height="fill_parent" android:layout_gravity="center_horizontal" android:mavity="center"></TextView><TextView android:id="@+id/TextView04" android:layout_weight="1" android:text="6" android:layout_width="fill_parent" android:layout_height="fill_parent" android:layout_gravity="center_horizontal" android:mavity="center"></TextView><TextView android:id="@+id/TextView02" android:layout_weight="1" android:text="7" android:layout_width="fill_parent" android:layout_height="fill_parent" android:layout_gravity="center_horizontal" android:mavity="center"></TextView>
<TextView android:id="@+id/TextView03" android:text="8" android:layout_width="fill_parent" android:layout_weight="1" android:layout_height="fill_parent" android:layout_gravity="center_horizontal" android:mavity="center"></TextView>
<TextView android:id="@+id/TextView09" android:text=" BONUS" android:layout_weight="1" android:layout_width="fill_parent" android:layout_height="fill_parent"></TextView>
</LinearLayout>
<LinearLayout android:id="@+id/Textyline" android
android:layout_width="fill_parent" android:layout_weight="1" android:layout_height="fill_parent">
<TextView android:id="@+id/TextView01" android:text="Trial Held" android:layout_width="fill_parent" android:layout_gravity="center_horizontal" android:mavity="center" android:layout_height="wrap_content"></TextView>
</LinearLayout>
<TextView android:layout_width="fill_parent" android:layout_height="fill_parent" android:layout_weight="1" android:textSize="7pt" android:layout_gravity="center_horizontal" android:mavity="center_horizontal" android:text="Net:"/><TextView android:id="@+id/wager" android:layout_width="fill_parent" android:layout_height="fill_parent" android:layout_weight="1" android:textSize="7pt" android:mavity="center_horizontal" android:layout_gravity="center_horizontal" android:text="Wager:"/><Button android:layout_width="wrap_content" android:text="-" android:layout_height="fill_parent" android:ellipsize="none" android:id="@+id/minus"></Button>
<Button android:layout_width="wrap_content" android:text="+" android:layout_height="fill_parent" android:id="@+id/plus"></Button>
<Button android:id="@+id/Button02" android:layout_width="wrap_content" android:text="Gamble" android:layout_height="fill_parent" android:mavity="center_horizontal"></Button><Button android:id="@+id/Button01" android:mavity="center_horizontal" android:layout_width="wrap_content" android:layout_height="fill_parent" android:text="Spin"></Button>
</LinearLayout>
</LinearLayout>
Thanks so much!
android
</LinearLayout>
</LinearLayout>
</LinearLayout>
</LinearLayout>
</LinearLayout>
</LinearLayout>
</LinearLayout>
</LinearLayout>
</LinearLayout>
</LinearLayout>
