** ANIDEES AI-08 - BIG CASE, SMALL PRICE **
OcUK Staff
26 Nov 2014
Stoke
New from Anidees, the AI-08 offers the wealth of features normally found on a full tower, whilst maintaining an aggressive sub £100 RRP. They come in windowed and non windowed variants, and both cases offer good watercooling support, dual PSU position mounts, 3 front 120mm Blue LED fans, a fan controller, space for 355mm VGA cards and more!
Stock will be available around mid October. Pre-Order now!
Anidees AI-8 Full Tower Case - Black @ £89.99 inc VAT
The Anidees AI-08 offers a spacious full tower case with extensive watercooling and air cooling options with space for E-ATX motherboards & long graphics cards, all at an attractive pricepoint.
Cooling is key for the AI-08 - there's space for up to a 280mm top radiator, a 360mm front radiator and a rear 140mm radiator. 3 120mm Blue LED fans are included at the front as standard, with space for 2 x 120/140mm top fans, and a 1 x 120/140mm rear fan. Up to 200mm PSU's are supported, with the option to mount at the top or bottom of the case to suit your need.
On the I/O panel there's 2 x USB3.0, 3 x USB2.0 and a fan controller as standard for plenty of connectivity. The Anidees AI-08 offers all the premium features you'd expect on a full tower chassis without the hefty pricetag!
Features
- Supports E-ATX, XL-ATX, ATX, m-ATX, mini-ITX MB.
- High end components support.
- Cable routing behind MB tray up to 25mm
- Supports 360/280/240/120 mm watercooling
- Dust filter in the front and top, and under the PSU for easy maintenance
- SSD cage behind MB tray
- Air cooling support 6 fans
- Two Power Supply Units support
- Fan controller and Fan Hub included
Specifications
- Available Colour: Black
- Material: Steel body / Plastic + Mesh bezel
- Dimension (D / W /H ): 440*230*530mm
- Net Weight: 8.5 kg / 18.7 lbs
- Motherboard Type: M-ITX,M-ATX,ATX,E-ATX
- 5.25" Drive Bay: 2
- 3.5" Hidden: 4
- 3.5" Exposed: 1(converted from one 5.25''Drive Bay)
- 2.5" Drive Bay: 4(2 from 2.5"HDD Cage)
- I/O Panel: USB3.0 *2,USB2.0 *3 ,Fan Controller,Audio* 1,Mic *1
- Expansion slots: 8
- Cooling System: Front:120mm Blue Led fan * 3,1100RPM (Included), 2x140mm, Rear:140mm x 1 (included), Top:140/120mm x 2 (optional)
- Power Supply: Standard ATX PS2 / EPS (optional)
- Maximum Compatibility: Graphics Card Length: 355mm (Remove HDD Cage), CPU Cooler Height: 175mm
- Water Cooling : 120/140/240/280mm Rad with on the top (Optional), 240/280/360 mm Rad in the front (Optional), 120/140 mm Rad in the rear (Optional)
- Model: AI-08B
- EAN Code: 6952093600268
Only £89.99 inc VAT.
ORDER NOW
Anidees AI-08B Full Tower Case - Black Window @ £96.95 inc VAT
Features
Specifications
- Side Panel: Windowed
- 3.5" Hidden: 4
- Model: AI-08B Window
- EAN Code: 6952093600275
Only £96.95 inc VAT.
ORDER NOW
These look unusually cheap. Trying to get the upper hand on Phanteks' price to quality, maybe?
